Is 1L enough for custom loop?
Go to solution Solved by felixbearpig,
Hi.
I already have 360 and 140 rad:s and only 1L of coolant.
I haven filled my loop yet,because i dond have pump yet.
So do i need another bottle of coolant or is 1L enough?
i dont think it is man i have 360 rad and 2 wb and i use over 1 liter
Hi.
https://linustechtips.com/topic/25687-is-1l-enough-for-custom-loop/
Hi.
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
Thanks.
Thanks.
I usually recommend 2. 3 if you want to play it safe for issues like spillages or if you ever need to top up.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
Then i might buy 3L
id say go with 2l becus i am using 2 120mm ek rads 1 wb and 1 bay res and i dont even use 1l
For a bigger loop it can be in the regions of 2L. He has twice as many radiators as you "technically".
My guesstimation for this loop would be 1.4L
Thanks again!
:D
Also think about your reservoir, if you have a 250mL or maybe even a 400mL tube reservoir or something like that you need a lot more in comparison.
I have 250x60mm res so i will be going whit 2L.
