Hi there @HEAD OF LEAD!
You can clone or backup using Windows, but in my opinion it's easier to use software that was made for this exact purpose. Since you have a WD drive, you can use the WD edition of Acronis True Image, which you can download from here: http://goo.gl/RtLCqV
Also, in case you haven't done this before, here are the steps how to do it: http://goo.gl/hYZ1jA
Hope this helps.
Cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
https://linustechtips.com/topic/256835-hard-drive-cloning/#findComment-3515444
