first of all sorry if its not the right place. !
i tried to build my own PC and got some problems
case:arc midi r2 window
ram : g.skill ripjaws X
motherboard: gigabyte z97 gaming 3
CPU cooling: h100i
http://postimg.org/image/jikbrvatb/
here u can see the first 2 problems
1. i installed the motherboard correctly? i had 7 holes on the motherboard. only 6 of them actually connected to the case- and the case had 9 screw holes.
2. the ram should be at the black slot of grey slot?it said 1234 so i place on 1 and 2
http://postimg.org/image/b93uzprpb/
here u can see my main problem!
3. i cant install the fans without damaging the ram slot, and couldn't  manage to place the ram when i installed the fans before the ram., idk how i should place it that the ram and the fans will both be fine.
http://postimg.org/image/llq5lsl8f/
here u can see another problem
4. the fan touches the red logo, it can cause problems?
http://postimg.org/image/3ycy1c0ov/
last problem
5. my friend told me ill have 2 cpu levers but got only 1... and its just fine.
i looked the internet and found someone with the same case & cooling that succeed doing this, but idk how, can u explain me?
pictures from his build:
http://i.imgur.com/CxZyz.jpg
http://i.imgur.com/ZKyug.jpg
http://i.imgur.com/UykKt.jpg
http://i.imgur.com/2XJvT.jpg
thanks a lot !!! :P
https://linustechtips.com/topic/256790-problems-while-building-my-pc/
Did you check the case before you mounted the motherboard? Most cases will have numbering for each mounting hole and which holes to use for what size motherboard. So make sure that's correct. If it isn't mounted correctly, then that will be the source of your problems. And your RAM looks to be installed correctly.
Make sure you have read all of the manuals carefully
If the rear I/O fit to the rear I/O shield, the motherboard should be ok, even though it doesn't use all the screw holes.
The Arc Midi R2 has very tight space for radiator mount on top. Some motherboards will fit, some don't. In your case, maybe they need to remove some material from the fans in order to fit. Or I believe the case has different mounting holes on top. You can move the radiator and give more room to the motherboard.
Socket 2011 has 2 levers for CPU. Socket 1150(z97 motherboard) has only 1.
CPU cooling: h100i
last problem
thanks a lot !!! :P
Your Motherboard is different from the one shown in the other set of pictures shown, that's why the fans fit on the other person's build. The ram is located in another position which allows access to the screws unlike your motherboard where the ram slots block the area where your fan screw holes are. If you look closely you can see that the other persons ram fits in between the 2 screw holes on the fan, or at least don't fit as closely.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
is your h100 offset away from the mobo? because you should be able to fit it just fine.
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
yup , i checked it, like 100 times,
and i read all the manuals but there was noting about it..
the i\o shield fits :)
what do u mean to remove some material?
i can place it only in 2 places - where its now or a bit into the drive bays but itll block them (and idk if the ram problem will be ok)
oh so my motherboard is fine i guess
so i need to change my motherboard , and ram? there is no way?
what do u mean?
its like at the only place its can be.
thx guys
what do u mean?
is your h100 centered in the case from left to right, or is it off centered to the left away from the mobo?
what do u mean?
i think i got u, do u mean where the water pipe placed?
the pipes are closer to the i\o .
