Pentium Anniversary Help
Go to solution Solved by Si3Rra_7,
i've seen people use this https://pcpartpicker.com/part/msi-motherboard-h81mp33
you can always get adapters from 2.0 to 3.0 , i use one since i have a h61 board , don't use flash drives much , and when i use them i plug them on usb3 on the back
As the X-Mas is here I want to get a few gaming systems for my some people. I want to build 5-7 using G3258's but the problem is I need boards that can overclock. I don't got enough Moolah to buy Z97 boards for everyone so i'm opting out for the either the
Asus H81M-E(https://pcpartpicker.com/part/asus-motherboard-h81me_
OR
Asus B85M-G R2.0(https://pcpartpicker.com/parts/motherboard/#c=88,92&qq=1&m=8)
Now the problem is that the H81 is cheaper but no USB 3.0 front headers but the B85 board is more expensive (by about $30) but does have front panel USB 3.0 headers.
If anyone can find a motherboard with overclocking in between 40-60 dollars and has USB 3.0 front headers.
Any help is appreciated.
(Also what do you think is better the B85 or the H81 board?
https://linustechtips.com/topic/256595-pentium-anniversary-help/
Top link doesnt seem to work, Just remember that not every CPU overclocks the same. They are all different and may not be stable/more stable than others.
You see I'm just looking for a board that has overclocking and has USB 3.0 Headers and is cheap
https://linustechtips.com/topic/256595-pentium-anniversary-help/#findComment-3511213
https://linustechtips.com/topic/256595-pentium-anniversary-help/#findComment-3511293
