So my PS3 is on Nat Type 2 and UPnP is Not Available..
On my router my Ps3 is in DMZ mode and UPnP is enabled and Advanced UPnP is enabled.. SO why is it not working?
Wireless and Wired Ps3 show the same results
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/256259-ps3-help/
I'm not one for NAT stuff, but I had a PS3 for about five years. When I replaced my router and started to receive the maximum possible internet speeds for my area, my NAT went from Strict to Open, and occasionally dropped to Moderate. This might not be the solution for you, though.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/256259-ps3-help/#findComment-3506947
Show us the full test results from your ps3
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/256259-ps3-help/#findComment-3506953
I get 77Mbs download and 21Mbs upload
Everything is correct Except it says UPnP: Not available
https://linustechtips.com/topic/256259-ps3-help/#findComment-3507110
Maybe it's your router's fault, is there anyway you could test another console or device with it for Upnp.
https://linustechtips.com/topic/256259-ps3-help/#findComment-3507196
i think it is my router but have no clue how to fix it. UPnP is enabled but when i did a test for it it said it couldnt get a UPnP response   (http://upnp-check.rapid7.com/)
It said  Congratulations! Your router did not respond to a UPnP discovery request.
https://linustechtips.com/topic/256259-ps3-help/#findComment-3507260
