Case fans!
Do you have any other suggestions as far as cases go? And how good are the rosewill fans?
Got a max price and country? (If not US/Canada/UK then linking retailers would be helpful)
My top sub $100 case would be the NZXT S340, but not a good choice if you need an optical drive and don't want to use an external one. Fractal Design's Core 3300 + 3500 look quite nice, the 3300 would be my choice since I've come to like that style of hard drive mounting.
And pretty decent, some very good stats. Airflow is very adequate, static pressure is rated as being quite high and noise level is quite low.
While I have no personal experience with them as of yet, I'm planning on buying a set within the next 3 months to try them out, they are quite highly regarded.
