autoclicker that only enables when i click and hold?
Snickerzz
i need an autoclicker that will enable when i click and hold my LMB and stops when i stop pressing LMB, also a hotkey to turn it on and off completely would help
anyone know of one that can do that^^ or could make one pretty please? c:
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
You can hire me to do it for you. For a mere $0.75 per click I will move into your home, sit at your desk and click anything on the screen for you!
This program you are talking about is very easy, and would be the PERFECT opportunity to learn a coding language for you! Now, go ahead my newly born coder, go into the world of coding!!
I can make it for 50 USD, or you could make it yourself free.
Here is how to perform a click in C#:
[DllImport("user32.dll")]static extern void mouse_event(int dwFlags, int dx, int dy, int dwData, int dwExtraInfo);// constants for the mouse_input() API functionprivate const int MOUSEEVENTF_MOVE = 0x0001;private const int MOUSEEVENTF_LEFTDOWN = 0x0002;private const int MOUSEEVENTF_LEFTUP = 0x0004;private const int MOUSEEVENTF_RIGHTDOWN = 0x0008;private const int MOUSEEVENTF_RIGHTUP = 0x0010;private const int MOUSEEVENTF_MIDDLEDOWN = 0x0020;private const int MOUSEEVENTF_MIDDLEUP = 0x0040;public static void LeftClick(){   mouse_event(MOUSEEVENTF_LEFTDOWN, Control.MousePosition.X, Control.MousePosition.Y, 0, 0);   mouse_event(MOUSEEVENTF_LEFTUP, Control.MousePosition.X, Control.MousePosition.Y, 0, 0);}
EDIT: Some of the Imports where wrong :P it should now be fixed!
Best regards Zahlio,
Unity asset developer - Game developer (http://playsurvive.com) - Computer Science student
And if you are too lazy to learn the syntax/api's of a compiled language, you can use a program called "autohotkey", I believe it can do what you are looking for.
| CPU: 2600K @ 4.5 GHz 1.325V | MB: ASUS P8Z68-V pro | GPU: EVGA GTX 480 clk 865/mem 2100 | RAM: Corsair Vengeance 1600 MHz CL9 | HDD: Muskin Chronos Deluxe 240GB(win8) && ADATA SX900 120 GB(ubuntu 12.04) | PSU: Seasonic x760 |
