Gotta remove PG without using a nail
So if you don't know already I've gotten 2 replacements already because of my fingernail damaging the adhesive layering which creates ugly bubbles. I've made a topic like this before but I'm too lazy to fish it out. Anyway one of the only suggestions was to use scotch tape. I've tried that and duct tape, both of which do not work. So is there a certain way to remove PG with tape that I'm just not doing correctly? Or can I do something else like a suction cup? Which I have not tried
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/254931-gotta-remove-pg-without-using-a-nail/
I would try a suction cup.
Yea but the only suction cups I have are in the car and that's away from the house right now
Are you seriously lazy in trying to get suction cups from the car?
It's best to use tape since it breaks the seal between the glass protector and the screen for it to come off easily, you need to get some tape that is extremely sticky since the glass is so smooth, as for suction cups try those small ones for lifting phone screens.
"and that's away from the house right now"  My mom drove off in it. I HAVE TO WAIT FOR HER TO RETURN
how much tape do I need to use?
What the fuck is PG?
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
phantom glass http://www.phantom.glass/ Linus did a review on it
So cryptic though...
I would try to use something like 3M exterior double stick tape, since that stuff sticks to basically everything, glass is a bit hard to stick especially with PG coatings, you'll need to carefully peel it off after.
If you go suction cup these will definitely do the job:
http://www.ebay.com/itm/LCD-Glass-Screen-Suction-Cup-Repair-Tool-Fr-Smart-Phone-Pad-iPhone-iPod-Macbook-/291282248556
so! masking tape didn't work. duct tape didn't work. scotch tape didn't work. 1 suction cup from a sunlight blocker didn't work, hope 2 actually fucking works! PG wasn't much help either as they wanted me to lift the glass up!
Not sure why your having so much trouble but it should lift pretty easily as long as you can get it started, that's usually the hard part, if you have a plastic phone opening tool try to lift it by hooking or grabbing the edge, and not the bottom of the glass course.
Other than that you may need a beefier or more suction cups, just go slow and take your time.
It's best to use tape since it breaks the seal between the glass protector and the screen for it to come off easily, you need to get some tape that is extremely sticky since the glass is so smooth, as for suction cups try those small ones for lifting phone screens.WAIT
WAIT WAIT WAIT. SHOULD THE TAPE COME IN BETWEEN THE GLASS AND PHONE?!
No don't do that, that will damage the silicone type glue they use to stick it to the phone, it should be stuck on the top of the screen protector but glass is very hard to get tape to stick to, since this method is more for the plastic type screen protectors.
The tape that I have is all shit. All of it. Doesn't stick if it's life depended on it. So what tape do you use to get it off? I'll also need to buy a good suction cup to try to get this off
Last time I installed one/removed one for a friend I used a plastic pry tool for fixing phones to carefully lift the edge, a little troublesome but it worked.
If you have some aluminum foil tape or some red tuck tape both of those are very sticky but not tacky so it won't leave a residue, not too sure what else you can really try without a suction cup.
