Hi Guys,
I am thinking of making the purchase of a XFX R9 290X DD Black Edition, and i need to know if my system will bottleneck it of cause any issues? My main concern is if my psu will cope and if my CPU will bottle neck the card.
Here are my system specs:
AMD FX-4170 4.4ghz OC
8gb zepplin RAM 1400mhz
Sapphire R9 270x OC
Asus m5a97 LE R2.0
Corsair RM650
Zalaman Z3 plus
My case is not the best so have a NZXT H440 on the way at the moment! My system uses about 300W max at the moment so wondering if the 650w PSU will be ok?
My CPU is very strong as it was a cherry picked special edition and is a great overclocker had it at 4.8ghz on air!
Cheers,
Samsterstorm  :D
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/254091-will-my-system-support-a-290x/
If could, but the CPU will bottleneck the system depending on the application.
And really, what you need for that system is a new CPU, not GPU.
You already have a 270X.
Also, your PSU is overkill.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
It will be fine, but you need to get a new cpu next
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
I'd say upgrade your CPU first and then worry about the GPU. ;)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
Cheers guys! Was going to go for a new GPU cause i heard that the 6 and 8 cores don't get me much more in terms of FPS which is what i am after. do you guys have any experience with the 6 and 8 cores? My 4170 is probably a very good one from the silicon lottery and don't want to spend £150 on a CPU only to get worse overclocking!
I am going to do a new CPU but i am waiting for the next FX lineup to come out so was gunna get GPU first then MB and CPU?
What you guys think?
Cheers B)
