What are you posting about?
I need help/opinions building my first computer. I don't know a whole lot
about different parts and funcionality, so I'm pretty much just going off videos,
what people say, other builds and listening to pcpartpicker if it tells me my parts
won't work. So any and all input is highly appreciated.
What do you want it to do?
I want to be able play most games at high settings, I do NOT want
to overclock, and I want the ability to graphic design or video edit.
4k compatibility would be nice, though not a main concern.
I also would like this build to last me awhile without having to
upgrade much.
What's your budget?
I'd like to stick around 2k but I am flexible if it's really worth it.
What do you have so far?
So here are my builds I've put together so far. I'd like to know
which one I should pick and/or how I could improve it.
https://pcpartpicker.com/user/Adorza/saved/#savedbuild_1588367
(P.S. If I go with the Gtx980, I may get a second one in the future for SLI but wouldn't with the Radeon)
Thanks!
-Adorza :wub:
https://linustechtips.com/topic/253956-build-options-please-help/
I've made some modifications, hope you like them :D
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($389.99 @ Newegg)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Gigabyte GA-X99-UD4 ATX LGA2011-3 Motherboard  ($228.99 @ Newegg)
Memory: Crucial 16GB (4 x 4GB) DDR4-2133 Memory  ($199.99 @ Adorama)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.97 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card (2-Way SLI)  ($329.99 @ NCIX US)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.99 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($90.26 @ OutletPC)
Total: $2046.13
Generated by PCPartPicker 2014-11-19 20:39 EST-0500
Edit: @Adorza make sure to follow your own posts :)
Edited by mosin40
@Adorza If you do not want to OC then a XEON will do great, here is a build:
CPU: Intel Xeon E5-2620 V3 2.4GHz 6-Core Processor  ($415.98 @ SuperBiiz)
Motherboard: MSI X99S SLI Plus ATX LGA2011-3 Motherboard  ($218.99 @ SuperBiiz)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($194.99 @ Adorama)
Total: $2029.12
Generated by PCPartPicker 2014-11-19 21:03 EST-0500
Edited by mosin40
Total: $2046.13
If you do want to OC then a XEON will do great, here is a build, i passed a little bit your budget:
Total: $2107.12
Generated by PCPartPicker 2014-11-19 21:01 EST-0500
Thank you so much for helping me! Much appreciated. Also.. I'm really new at this, I did follow my own post, but what exactly does that do?
It sends you notifications of ppl who posted in your thread
This can be useful when you're viewing other posts/topic/threads in the Forum
Edit: You're welcome
Edit 2: I know the builds i posted are good, but if you had a little more budget i would go for a 8-10 core Xeon (and upgrade it in 3-4 years) to have more horsepower when rendering and video editing
For now, how should I choose between the Intel Xeon E5-2620 and the Intel Core i7-5820K?
I just went to http://ark.intel.com and compared both cpus.
The advantage of the Xeon is that it has 40 PCI-e lines and consumes less power, although the core clock is kinda low and has a high price
The advantage of the 5820k is the overclocking capability (you can improve performance with it), but has a higher TDP and less PCI-e lines, 28 to be exact. low price
Though decision, but i will go 5820k, (not sure about what others would say)
Make sure to watch @LinusTech new vid on overcloking the 5820K
PS: I know that you don't want to OC, but at least you should try it, it would be a great experience, i never done that cuz i own a laptop... Also if you're going build the PC, you will love it :D
