https://linustechtips.com/topic/253834-first-build/
de.pcpartpicker.com?
No need for 2400MHz ram
A dvd drive, you really need it?
maybe a liquid cooler?
I agree you should stick with 1866MHz theres not much gain with going with 2400Mhz and your paying allot more
If you want to spend the money on ram just get 8 GB stick instead
https://linustechtips.com/topic/253834-first-build/#findComment-3477321
