what will cross fire
By
Kobrastachka
in Graphics Cards
in Graphics Cards
Solved by mapegl,
Any Pitcairn chip should work:
7870,7850,270,270X
7870 Boost (7870 XT) will not work because it is a Tahiti XT chip.
With AMD it is pretty easy, just look for the chip used in the card. If they are the same, numbers don't matter. ;-)
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases6 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
