building a list for a friend, budget is $700- ish
Preferably a cheaper case ~under 100$ usd.
A windowed side panel would be nice.
Mobo:  Asus z87-a  Lga 1150
https://linustechtips.com/topic/25286-cheap-atx-case/
Considering the budget, maybe don't go for Haswell?
Unless you already bought the parts, I would like to give some input on a $700 build. What's the use of the build? Gaming/rendering/editing?
If you already bought the parts, you could go with these:
MSI TC http://pcpartpicker.com/part/msi-case-tc128
Thermaltake Chaser A31 http://pcpartpicker.com/part/thermaltake-case-vp300a1w2n
NZXT Tempest 410 http://pcpartpicker.com/part/nzxt-case-t410e001
https://linustechtips.com/topic/25286-cheap-atx-case/#findComment-320426
I wouldn't necessarily call under $100 'cheap', since there are so many cases between $50 and $100 that are downright awesome.
-BitFenix Shinobi (comes in white, black, with red/blue/green/silver trims and with/without window)
-Fractal Design R4 (should be within the budget normally)
-Fractal Design Arc Midi (though not great with dust)
-Corsair C70
As for actually cheap cases, how about the BitFenix Merc? Very cheap without sacrificing ease of building in. And if you don't mind going micro-ATX, which unless you're actually going to use all the PCIe lanes of a full ATX you should, maybe the Fractal Design Core 1000 is enough?
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/25286-cheap-atx-case/#findComment-320575
Ended up going 8320 instead, haswell platform+cpu were just overly spendy lol, although I did make it work, but it was like 812$ lol
https://linustechtips.com/topic/25286-cheap-atx-case/#findComment-320883
The Define R4 is on sale on newegg for 80 bucks till the 13th
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/25286-cheap-atx-case/#findComment-321833
