So this is very weird, I was doing a stress test on my CPU because it was reaching higher temperatures than normal. I was looking at temperature and voltage and I noticed that the CPU was staying pretty cool at about 65 degrees, but then I saw the voltage change and the temperature shoot up. It was odd though because the voltage went from 1.170 to 1.166. I opened another monitoring software and the voltage didn't go to 1.166 but it was moving a lot, I closed the program and opened it again and it wasn't changing the voltage. I then opened the other monitoring program and the voltage was changing again. I'm not sure if it was the program or the CPU but whenever the voltage changed the temperature shot up so I don't know. Please help it would me a lot.
https://linustechtips.com/topic/252820-cpu-or-motherboard-problem/
