CPU going above set voltage?
Solved by Faceman,
You're always going to get some overvolting, often referred to as vBoost. Its a result of LLC and adaptive voltage. During stress testing you are always going to get more than in real-world scenarios. To avoid this, set your voltage to manual/override/constant/static whenever stress testing, then revert back to adaptive when not stress testing. Also, set your LLC to medium or 4/8, whatever your motherboard calls it.
Even for me running at 1.160v will see 1.170v when I'm gaming. I use adaptive voltage and 3/8 LLC.
