Hello Everyone,
So a few months ago I built a PC for a friend of mine. Now everytime he opens a game it crashes after approx. 1-7 minutes it gives a balck screen and you have to manually reset the PC. When its booted up again I get the standard bluescreen message with the log code 1043 I wil attach a copy of the dump file. I have tried a lot of things to help the problem but nothing helped here is the list:
Here is a link to the dump file: http://www.filedropper.com/111714-9360-01
- Memtest gave 1 error in a period of 36 hours
- Tested the PC with one DIMM at a time = crashes each time
- Rebuild the PC = did not help
-Reinstalled Windows 7 did not help
- All the drivers are up to date with the stable version
I really dont know what to do anymore so if somebody could help I would be very very gratefull.
Specs:
I7 4770K
Asus Maximus VI Formula
Asus GTX780ti
2x Samsung 840 evo 120 GB (RAID0)
2X WD 3TB Red Edition
Cyber023
If you need anymore data or information please ask
post-26344-0-57353900-1416258665_thumb.p
  CPU:   Intel I5 3570K @ 4,6 GHZ   -- MOBO: Asrock Z77-Extreme4 -- GPU: EVGA GTX 770 2GB -- PSU:Corsair TX750M -- R AM: 16 GB 1333 MHz -- HDD: 2x 2TB -- 1x 120 GB HyperX SSD -- AUDIO: Creative Audigy 2 -- CASE: Fractal Design R4
-- Actually Like Windows 8 --
https://linustechtips.com/topic/252565-bsod-problems/
BTW It only happens with games tried about 3 games, not with other heavy load programs such as Abobe CS6 Suite
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460400
did you overclock anything if so how far? Did you update bios on mobo? Did you try clearing cmos?
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460403
I've Set default setting in BIOS and cleared CMOS
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460427
did you just do that? also try updating bios
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460435
Did that didn't work
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460455
Try re-installing windows. I had similar problems with my rig and I thought it might just be an install error. Just make sure to backup any wanted data on your boot drive.
Read post tried reinstalling Win7 didn't work
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460482
has he checked for bent cpu pins
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460505
What do you mean it didn't work? Usually when you get to the drive selection, select new then format it. (Make sure the desired one is selected) then hit ok and follow the steps.
I'm probably playing a game right now...
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460506
No but don't think this is it because it only crashes with gaming not CPU intensive proceses like rendering.
I reinstalled windows but the crashes still happen
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460530
just check it can lead really wierd issus
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3460555
The CPU seems to be installed correctly, so how would a bent pin occur? Just saying. :)
Edit: I didn't look at your last post. sorry.
Try each ram stick (take one, try launching game, shutdown, etc.)
https://linustechtips.com/topic/252565-bsod-problems/#findComment-3462159
