2 fans can run at lower RPM's and still provide the same cooling potential together, making for lower noise at equal performance or more potential performance at the same noise. I would go for the FTW ACX since that is an awesome 750Ti
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/252234-single-vs-dual-fan/#findComment-3456423
^^^^That and FTW will have more OC potential
First Build:
Case: Bitfenix Prodigy Black          GPU: MSI R9 270 Gaming@1050/1500         CPU: i5 4570          Motherboard: ASUS H81I Plus          PSU: Corsair CX600          RAM: 8GB Crucial Ballistix Sport XT         Cooling: 230mm Bitfenix Spectre Pro Intake; Corsair AF140 Rear Exuast; 2x120mm Stock Case Fans Top Exuast        Storage: WD Blue 1TB          OS: Windows 8.1 Pro 64 Bit
https://linustechtips.com/topic/252234-single-vs-dual-fan/#findComment-3456448
is that because of 2 fans or the six-pin
Both, but mainly the 6 Pin
First Build:
https://linustechtips.com/topic/252234-single-vs-dual-fan/#findComment-3456461
I'm pertty site sure amd has a better card for less money cant remember is it the 260x
Just checked linus holiday buyer video that he posted two days ago the r7 260x is the card that performs similarly but alot cheaper than the gtx 750 ti
My Gaming Setup: CPU: AMD FX-8350  |  CoolingCooler Master Hyper 212 Evo   Motherboard: Asus M5A97 EVO R2.0   Ram: Corsair 16gb 1600mhz lp (2x8)   GPU: Msi Gtx 970 |  StorageSeagate Barracuda 1tb & Samsung 840 Evo 120gb   PSU: XFX 550w Core Edition   Case: Corsair 760t   OS: Windows 7 Professional 64 bit
Peripherals: Keyboard: Corsair K70 Cherry Mx Brown   Mouse: Corsair M65 Black   Speakers: Microlab FC20 40w 2.1   Monitor: LG 29UM65 29" 2560x1080 IPS 5ms Ultra Wide
https://linustechtips.com/topic/252234-single-vs-dual-fan/#findComment-3456478
its depends on the definition of performance, 750 ti is getting praise for it's power efficiency and less heat output
https://linustechtips.com/topic/252234-single-vs-dual-fan/#findComment-3457781
In the UK you can get r9 270s for near the price of 750ti.
GG :D
First Build:
https://linustechtips.com/topic/252234-single-vs-dual-fan/#findComment-3458336
