So I got Ai suite that has Dual intelligent processors 4. Is it possible to update it to the 5 version? Here are the differences
Not sure if it's possible, you should check the official ASUS site, and then look up your MOBO and check if they offer AI-suite 5 for your board, if not there are probably some changes in the hardware that will stop the software from working properly.
You could always send them an e-mail and ask.
https://linustechtips.com/topic/252040-ai-suite-question/#findComment-3454243
I tried sending an email but can't find their adress... ASUS's website is so complicated when trying to find contact info.
https://linustechtips.com/topic/252040-ai-suite-question/#findComment-3454373
I'm assuming it's a ROG board? They have their own forum here, with it's own software sub-forum, you might want to check/post there.
https://linustechtips.com/topic/252040-ai-suite-question/#findComment-3454483
