$700 build help (Re-post)
Solved by BrandedUpontheGrave,
Mmm.. That i7 is a hyperthreaded dual core from what I've found, the Pentium K (G3258) is a non hyperthreaded dual core buuut it's clock speed is higher at stock by a whole Ghz!
There are non Z boards from Asus that will do the overclocking with a BIOS update (Asus snuck that one in to their cheaper boards) and it actually OCs quite well even on the stock heatsink (having 2 cores can work wonders) so you could potentially run stock I've heard tales of 4.5 on it... Not sure how valid those are though.
Other than that the only thing you could feasibly snip is that case, everything else (minus the MOBO) is pretty much as low as you could get it.
