hello everyone,
this is my first time posting in this wonderful community.
i need some help with my build.
i dont know what cooler i should pick!
heres my build :
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($328.97 @ OutletPC)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  ($89.99 @ Amazon)
Storage: Intel 530 Series 240GB 2.5" Solid State Drive  ($119.99 @ Amazon)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($348.99 @ NCIX US)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($49.99 @ Amazon)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($13.99 @ Newegg)
Total: $1316.88
Generated by PCPartPicker 2014-11-15 21:08 EST-0500
i am programmer(mostly game dev) and i also do some videoediting and 3d modelling/animation.
i also play quite a few games, although i am not so hardcore.
please tell me if this build is good enough. i heard the hx750 is obsolete and i want to know whether all my parts are compatible.
and should i buy a seperate sound and network card, or are they part of the motherboard?
Please suggest me a good cooling system.
Thanks!
https://linustechtips.com/topic/251500-help-with-my-build/
what will you be using this for? also you cant overclock with an H series mobo
https://linustechtips.com/topic/251500-help-with-my-build/#findComment-3447141
i already posted its use (gaming , programming , 3d modelling and rendering ). can you please then suggest a good psu and a cooler?
whats your budget for thoes 2 items
https://linustechtips.com/topic/251500-help-with-my-build/#findComment-3447239
