I need some help picking out fans for top exhaust. I have an Enermax Ostrog GT case. I can't decide on whether I should use a 20-23cm fan or two 14cm fans for the top exhaust. I also need some suggestions on what fans I should use for the exhaust depending on the size. I like the 2 14cm because I can cover the gaps with less material, but I wouldn't mind a 20-23cm fan. Thanks for your help ahead of time.
https://linustechtips.com/topic/251013-top-exhaust-help/
2 Noctua 140mm fans i would say, NF-A14 PWM fans
I figured someone was going to suggest noctua fans. I would go for those but, I forgot to put that I wanted to stay color coordinated in this case. Black and red or just black. The industrial noctua fans are too expensive for me at this moment.
https://linustechtips.com/topic/251013-top-exhaust-help/#findComment-3441347
