So, I am looking to build a relatively quiet gaming rig. Will (hopefully) have a gtx 780 windforce in it, and what I'm wanting advice on is the CPU cooler. Okay, bearing in mind I am going to be using an R4, and I am willing to stump up to replace any stock fans with noctua fans, should I go with air cooling, or mount a H100i in the top?
Also, will there be a heat problem do you think, if I only use the rear exhaust?
https://linustechtips.com/topic/25084-quiet-cpu-cooling/
I think you should go with a Noctua NH-D14 for great quiet but powerful air cooling.
There shouldn't be a heat problem if you use gpu boost 2.0 correctly. The heat buildup will probably mostly be from the gpu.
If you go with the h100i, set the rear to intake for better cooling.
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317853
H100i would be best
Lol, thanks guys, guess I'm going to be need a few more votes either way. :P
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317858
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317863
H100i with Noctua fans on low RPM. Or any decent aircooler with Noctua fans.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317875
you can buy any cooler you want, but if you slap a 3200rpm fans on them they wouldn't really be quiet :|
make sure you have enough head room in your budget for your fans, I've spent over 250 bucks just figuring out the perfect fans for me.
hope that helps :)
*edit*
forgot to mention, I settled for cougar vortex fans - I didn't even notice if they were on most of the time :)
Check out the build: Used to be Obot, now Lilith
Shameless: Me
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317907
If I were to use a H100i, would it make much of a difference to the CPU temp if I used it in exhaust, instead of intake?
Not really no.
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317920
The H100i fans are really loud so I wuold personally go with the Enermax ELC240-TB.
Closed loop liquid cooler, 240mm rad and has some Enermax TB Silencers on it so its quiet. I have one in my HTPC.
Nothing Is True, Everything Is Permitted
(Do not try to work the meaning out you will go insane I have tried it)
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317943
I would use noctuas in a heartbeat if they weren't colored like crap and vomit
Why do i always get blue screens? Why not a red one for a change?
  CPU: 2920x  GPU: Sapphire HD 7950 Vapor X  MOBO: X399 Taichi  RAM: 4x 8GB Trident Z RGN 3200/14  CASE: 900D  OS SSD: Samsung 960 Evo 512GB  Storage: 20TB NAS  PSU: Corsair RM1000i  CPU COOLER: NH-U14S TR4 OS: Arch Linux Keyboard: Ducky Shine 3 TKL  Mouse: MX Master 2S Headphones: BD DT 770 PRO 250 Ohm
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-317951
I could be wrong or they may be different types of fans but at Computex, Noctua had some black fans. I can't recall everything about then at the moment though.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
- Albert Einstein
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-318026
I think they were low range fans that haven't come out yet. But if i recall their top of the line products are still going to use the usual color scheme
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-318072
Oh cool, cheers, I wasn't sure
- Albert Einstein
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-318085
The black fans from noctua are industrial fans that are made for performance and industries that could not care less about quiet fans
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/25084-quiet-cpu-cooling/#findComment-318806
