Gaming pc - First Build
Go to solution Solved by the jolly roger,
go for a hyper 212 evo for the cpu cooler, performs better and should cos a tiny little bit more
go for a 990fx chipser motherboard, liek the asrock 990fx extreme 3
SSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSDSSD
Hello guys, i want your opinion for this build (oh i will use this pc for gaming) :
Type|Item|Price
**CPU** | [AMD FX-8350 4.0GHz 8-Core Processor](http://de.pcpartpicker.com/part/amd-cpu-fd8350frhkbox) | €150.90 @ Caseking
**CPU Cooler** | [Cooler Master Hyper TX3 Evo 43.1 CFM CPU Cooler](http://de.pcpartpicker.com/part/cooler-master-cpu-cooler-rrtx3e22pkr1) | €22.80 @ Amazon Deutschland
**Motherboard** | [ASRock 970 Extreme3 ATX AM3+ Motherboard](http://de.pcpartpicker.com/part/asrock-motherboard-970extreme3) | €74.89 @ Home of Hardware DE
**Memory** | [Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1866 Memory](http://de.pcpartpicker.com/part/corsair-memory-cmy8gx3m2a1866c9b) | €84.34 @ Amazon Deutschland
**Storage** | [seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive](http://de.pcpartpicker.com/part/seagate-internal-hard-drive-st1000dm003) | €52.69 @ Amazon Deutschland
**Video Card** | [PowerColor Radeon R9 280X 3GB TurboDuo Video Card](http://de.pcpartpicker.com/part/powercolor-video-card-axr9280x3gbd5t2dheoc) | €212.74 @ Home of Hardware DE
**Case** | [Cooler Master K350 ATX Mid Tower Case](http://de.pcpartpicker.com/part/cooler-master-case-rck350kwn2en) | €43.25 @ Amazon Deutschland
**Power Supply** | [Cooler Master Thunder  600W ATX Power Supply](http://de.pcpartpicker.com/part/cooler-master-power-supply-rs600acabd3) | €45.65 @ Amazon Deutschland
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | €687.26
 | Generated by PCPartPicker 2014-11-14 21:47 CET+0100 |
If you have some better ideas write them down pl0x!
Thank you!
https://linustechtips.com/topic/250726-gaming-pc-first-build/
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/250726-gaming-pc-first-build/#findComment-3437226
Here is a idea that I would do, get a 280(Non X) with a better cooler and then overclock it so it is basically a R9 280X
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/250726-gaming-pc-first-build/#findComment-3437232
