Smallest full-ATX case?
Go to solution Solved by imthewalrus,
what is a dremmel? i am no native speaker, so i don't know what it is ...
and i am pretty good manually, for example i build my own bass
The prodigy originally fits micro atx motherboards which have 4 expansion slots (or fit 2 graphics cards). Atx motherboards have 7 or more expansion slots and are too big for the prodigy. However if you are handy with tools (Such as a dremmel which is used to cut metal) and are creative there are actually ways in which people fix the prodigy and mount an atx motherboard in the prodigy but it is really complicated.
Take a look at this thread:
http://forums.bit-tech.net/showthread.php?t=253141
picture of dremmel:
Dremel%2012V%20Lithium-ion%20Rotary%20To
Hey guys!
I won a giftcode from amazon, and want to spend it on a new case, cause mine is really bad (some 40$ case).
I really like a small sized case, that still supports a full ATX motherboard (gigabyte h87-hd3).
I hope you can help me.
I got no prizetag.
Greetings
Prime ;:)
https://linustechtips.com/topic/250481-smallest-full-atx-case/
Define R4
The R4 is still a large case. He is asking for the smallest full-ATX case.
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3434432
Smallest one I can find: http://www.amazon.com/dp/B00JJ3O9O2/?tag=pcpapi-20
Edit: Almost one week later I found out this is my 800th post.
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3434449
Corsair Spec series is the smallest I've found
Asus MAXIMUS VII Gene 2 x 8GB G.Skill 16GB 1600 Mhz Intel 4670k @ 4.3 Ghz Corsair H100i w/ stock fans EVGA GTX 770 SC Intel 750 Series SSD 240GB, Samsung 840 SSD 240GB WD Caviar Green 2TB Seasonic X-650 V3 2 x 140 mm Noctua A14 PPC, 120mm LED Corsair AF120
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3438756
NZXT S340 is pretty small for an ATX, although I don't know if that's what you mean by "Full ATX" although it will fit an ATX motherboard.
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3439064
the silverstone grandia gd09 is the smallest ATX case available on the sub $100 level. If you are into modding the Bitfenix prodigy can easily fit an ATX motherboard but you will need to change a lot of things including I/o and orientation of the case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163257&cm_re=silverstone_gd09-_-11-163-257-_-Product
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3440100
are there some sort of videos for it? because the bitfenix looks really awesome ;)
btw: does your case and the bitfenix case have space for a msi gtx 770?
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3443321
Again the BitFenix does not fit ATX motherboards unless you completely mod it and that requires the expert use of a dremmel, it does have space for a gtx 770. The Grandia on the other side will fit most graphics cards from stock settings,
Here is a review of the grandia, there is unfortunately no videos
http://www.bit-tech.net/hardware/2014/10/13/silverstone-grandia-gd09-review/1
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3443575
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3443792
picture of dremmel:
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3444545
picture of dremmel:
a ok, yeah i am ok with that. used it to build my bass
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3444579
You will however need another case you can get the back panel from to use as the back panel inside the prodigy. Look at the thread I attached and you will see what they did.
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3444600
yeah, thanks for this. Luckily i already have a very cheap case atm, which looks just boring (a 30$ bitfenix case -  for the price the build quality is really good.
https://linustechtips.com/topic/250481-smallest-full-atx-case/#findComment-3444621
