Here is my current build: http://pcpartpicker.com/p/fsy9yc
I need a mechanical keyboard, mouse, and headset. I just don't know which ones. There are so any to choose from.
I don't need a monitor.
I would like my keyboard and mouse to be with same brand, with a nice price tag. Not like middle of the road, but not super expensive premium, like a good imbetweener. I need to be able to have nice team speak on my headset. But no Astros with alright audio and amped up bass, like actuall good ones. Wired or wirless, I have no preference.
Thanks so much. :D
https://linustechtips.com/topic/250461-peripherals-help/
Keyboard: CM Storm, Filco, Das, Ducky, Corsair, Razer non-chroma (Because khail :c)
Mouse: Corsair M45, Logitech G502, Razer Deathadder
Headset: Kingston HyperX cloud, anything above I recommend headphones + Modmic 4.0
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434104
the raer keyboard for 2014 non chroma has khail
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434109
the raer keyboard for 1014 non chroma has khail
Oh shit, then don't get that either. Cherry MX for the win.
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434110
CPU Cooler: Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler  ($74.99 @ Newegg)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($121.99 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($349.99 @ Amazon)
Case: BitFenix Ronin ATX Mid Tower Case  ($69.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan  ($7.97 @ OutletPC)
Keyboard: Corsair K70 Wired Gaming Keyboard  ($129.99 @ Amazon)
Mouse: Corsair Vengeance M95 Wired Laser Mouse  ($62.99 @ NCIX US)
Total: $1370.08
Generated by PCPartPicker 2014-11-14 08:47 EST-0500
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434127
yea i did corsair on his with non vengance parts so they dont have the tato gone wrong logo
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434132
What would something above the cloud be? (Around the 150$ price range)
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434140
do you need mic or can you do mod mic if modmic senheisser hd558 with mod mic they are open so people around you can hear what you are listening to but they have amazig soundstage what allows you to snipe someone with you eyes closed trust me friend of mine did it at lan
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434148
Mionix mouse, Corsair keyboard :)
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434150
Sounds good to me, thanks.
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434156
great i wish you the best with your build
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434164
ATH-M40x with Modmic 4.0, or ATH M50x
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3434169
For now. Although I've already settled with myself that if a particular switch maker enters the market, Cherry is dead to me. They're good, but they're not that good, and for some applications, far too slow
That said, I didn't find Kailh switches to be any worse than Cherry when testing them side by side. In a blind test, I wouldn't be able to tell
CPU: Intel Core i7-4770k | Mobo: MSI Mpower Max | Cooling: Cryorig R1 Ultimate w/ XT140 front Fan | GPU: EVGA GTX 770 Dual SC SLI | Case: NZXT H440 | Case Fans: Phanteks PH-140SP x5 | PSU: EVGA Supernova P2 1000W | RAM: 16GB Crucial Ballistix Tactical Tracer | SSD: Kingston HyperX 3k 120GB | HDD: Seagate Barracude
Keyboard: Razer Blackwidow Ultimate 2013 | Mouse: Razer Deathadder 2013 | Headphones: Sennheiser HD438s | Mousepad: Razer Goliathus Control | Monitor 1: Benq XL2430T | Monitor 2: BenQ RL2455HM
https://linustechtips.com/topic/250461-peripherals-help/#findComment-3435200
