Broken link
First Build:
Case: Bitfenix Prodigy Black          GPU: MSI R9 270 Gaming@1050/1500         CPU: i5 4570          Motherboard: ASUS H81I Plus          PSU: Corsair CX600          RAM: 8GB Crucial Ballistix Sport XT         Cooling: 230mm Bitfenix Spectre Pro Intake; Corsair AF140 Rear Exuast; 2x120mm Stock Case Fans Top Exuast        Storage: WD Blue 1TB          OS: Windows 8.1 Pro 64 Bit
https://linustechtips.com/topic/250149-build-advice/#findComment-3429813
Wouldn't change anything - apart from OS to Windows 8.1 and maybe changing ram to Corsair Vengeance Pro (as it nicely colour matches the Motherboard).
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/250149-build-advice/#findComment-3429841
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($324.99 @ NCIX US)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler ($94.99 @ Newegg)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard ($117.98 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($154.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($119.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Video Card: MSI GeForce GTX 980 4GB Video Card ($549.98 @ NCIX US)
Case: NZXT H440 (White/Black) ATX Mid Tower Case ($109.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ NCIX US)
Total: $1597.88
Generated by PCPartPicker 2014-11-13 17:03 EST-0500
First Build:
https://linustechtips.com/topic/250149-build-advice/#findComment-3429857
See it here:  http://pcpartpicker.com/p/z4FxWZ
Uses:
Gaming
editing
rendering
DAWs
-Budget: $1,700 USD
Any advice regarding anything is appreciated!
You may want to consider a motherboard the has dual band a/b/g/n/ac WiFi and Bluetooth 4.0 Asus Z97-PRO(Wi-Fi ac).
Windows 8.1 64-bit OEM will be supported longer than Windows 7.
https://linustechtips.com/topic/250149-build-advice/#findComment-3429870
Upon inspection of your build, eveything seems to be okay. But if you can strech to $1840 than add a GTX 980
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  ($203.99 @ NCIX US)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card  ($556.80 @ Newegg)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($99.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($88.98 @ OutletPC)
Wireless Network Adapter: Rosewill N900PCE 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($24.99 @ Amazon)
Total: $1843.67
Generated by PCPartPicker 2014-11-13 17:04 EST-0500
https://linustechtips.com/topic/250149-build-advice/#findComment-3429875
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler  ($117.99 @ Mac Mall)
Motherboard: Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard  ($154.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.97 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($368.99 @ NCIX US)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($109.99 @ Micro Center)
Total: $1615.84
Generated by PCPartPicker 2014-11-13 17:42 EST-0500
CPU: Ryzen 7 9850X3D CPU Cooler: Lian Li GA II LITE 360mm GPU: MSI 5070 Ti 16G GAMING TRIO OC Motherboard: Asus X870-P Prime WiFi RAM: Flare X5 Series 32GB (2 x 16GB) DDR5-6000 Storage: SanDisk EXTREME 500GB M.2 + Samsung 970 EVO Plus NVMe 1TB + Samsung 990 PRO NVMe 4TB PSU: Seasonic CORE GX 1000W ATX 3.1 Case: Phanteks 523 Series XT Pro Ultra Monitor: Dell S2716DGR 27" 144Hz G-SYNC Mouse: Logitech G502 Hero Wired Keyboard: Corsair K70 LUX Cherry MX Brown Speakers: Bose Companion 2 Series III Headset: HyperX Cloud Alpha Microphone: Razer Seiren X
https://linustechtips.com/topic/250149-build-advice/#findComment-3430138
