i don't know if this the right section for this post,if it's on the wrong section please moved it.
So can anybody help me how to set up a ps3 controller for pc. The video on YouTube are to complicated for me.
Thank You!  (PS. I'm using a official ps3 controller)
https://linustechtips.com/topic/249885-how-to-use-ps3-controller-in-pc/
To be honest if the videos on youtube are too complicated then you probably just aren't smart enough to do it. They will be able to explain things much easier than any text will be able to.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
http://www.motioninjoy.com/download
Works nicely for me. Just hook up the controller. Install the program. Open the program. Go to drivers tab, check the boxes and install.
go back to first tab and choose a profile. I usually use the Xbox360 profile, because that controller basically works with every game.
any questions, shoot a message at me. ;-)
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
Sometimes motion joy gave me a bsod. Be careful.
I say: Avoid MotionJoy. nothing but adware now. I was okay and popular in the past but was abandoned and turned filled with adds, not good option now.
You should check out the pcsx2.net forums, theirs a few choices in software to try out and a lot of feedback on the site so it's safer then older shady software.
check out: http://forums.pcsx2.net/Thread-XInput-Wrapper-for-DS3-and-Play-com-USB-Dual-DS2-Controller -Wrapper to make PS3 controller appear as 360 contoller.
I use motioninjoy 0.7.1 and it is absolutely fine. no big ads or anything....
Older version may not have ads, but your also using out dated software so that's your choice. MotionJoy isn't that great anyway it just spread really far and got popular at one point and people keep pointing back to it after the fact, there are more options now it's okay to try other things.
This x1000
The wrapper DS3 service is definitely the way to go. Worked easily, nothing too complicated about it. Never did get MotionJoy to work.
If you don't want to use Better DS3 or Motioninjoy, you can use SCP DS3, and install it with this tutorial here:
I use that and it's much much better than using Motioninjoy
"It seems we living the American dream, but the people highest up got the lowest self esteem. The prettiest people do the ugliest things, for the road to riches and diamond rings."- Kanye West, "All Falls Down"
