i got it to work but have this problem now :angry: 65tpag.png
right click desktop > screen resolution > advanced settings > monitor tab > Colors: "set to true color (32 bit)"
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/24969-igpu-not-working-help-plz/#findComment-317048
I went reading http://technet.microsoft.com/en-us/library/cc732199%28v=ws.10%29.aspx
What bios are you using? http://support.asus.com/Download.aspx?SLanguage=en&m=P8Z77-V&p=1&s=39 You can get the .CAP here. Extract the file and drop it into the root of a thumb drive. It's very easy to flash the bios from within the bios, you don't have to the green usb port+flash button method unless you're bricked.
https://linustechtips.com/topic/24969-igpu-not-working-help-plz/#findComment-318100
