See, I have a MSI 970A-G46 and I have used already a fan connector for CPU, and other two for fans. I was searching in the motherboart a connector (3pin) for another fan but I can't find it. I saw many people connects it to the Power Supply but i dont find any proper connector. CAN SOMEONE HELP ME !!!
Reply A.S.A.P.
https://linustechtips.com/topic/249559-need-to-connect-another-fan/
Reply A.S.A.P.
WITH this you can connect direct to PSU (fan spin at full speed all the time though)
With this you can connect two fans to the same header on the motherboard (both fan spin at the same speed...better)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
How are they called in the market ?? Thankyou
the first is called a 4pin to molex adapter and the second is called a fan splitter...they maybe have a more scientific name for them but i'm not sure but you should be able to find them easily...
THANKYOU ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
