Hey everyone, my year old Seagate 7200RPM 1TB drive has been making an intermittent sound. It sounds like a mix of a click and a crunch.. Almost like a chirping sound. It does it every few minutes, and sometimes it doesn't do it at all. It only makes the sound when idle, if I'm using it, then it never happens. I haven't noticed any performance degradation, and the drive sounds normal except for the chirp noise that it makes every so often...
Ideas??
CPU: Intel i5-2320 @ 3.9gHz
GPU: MSI GTX 670 PE @ 1411/7387
I wanna go fast! :P
https://linustechtips.com/topic/24955-hard-drive-noises/
Ditch it, if a hard drive starts making any kind of noises no matter if it's idle or not, it's untrustworthy.
Ususally it makes these kinds of noises if it isn't getting enough power, but considering it doesn't click when it works then I don't know.
https://linustechtips.com/topic/24955-hard-drive-noises/#findComment-316060
Back everything up and get another drive.
https://linustechtips.com/topic/24955-hard-drive-noises/#findComment-316064
I wouldnt ditch it, but if it has any valuable data id back it up
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/24955-hard-drive-noises/#findComment-316065
It does get enough power though. I have a 750 watt corsair PSU. I use 280 watts under full load.
I wanna go fast! :P
https://linustechtips.com/topic/24955-hard-drive-noises/#findComment-316099
I have a Seagate HDD and its also about a year old and making these noises when its coming out of idle, When i open my computer and access the drive it does lag.
I have played around with some of the windows settings though (predictive HDD usage, caching and all that stuff). I do have some WD drives, but the seagate is making a louder noise than the head parking.
My Rig - Intel 4670K (4.3Ghz) Cooler Noctua NH-C14| Gigabyte Z87X-UD5H | 16GB GSkill 1866MHz | Gigabyte 7970 OC  | Samsung 840 Pro 128GB | Thermaltake Overseer RX-I  | Thermaltake TP Qfan 750w
Brothers rig- AMD FX-6100(4.1 GHz) | Gigabyte 990FXA -D3 | 8GB GSkill 1866MHz | Sapphire 7870 Ghz OC  | Kingston HyperX 3K 120Gb | Antec 900 v3  | Antec Neopower Blue 650w
https://linustechtips.com/topic/24955-hard-drive-noises/#findComment-317694
