Hi, so obviously said in the title, this will be my first computer build. Right now I share a computer with my dad which my sister's boyfriend build, however he has an on board gpu (according to pc spec the Intel Hd Graphics 3000). I'm looking for a computer for my room which has carpet so I need a case with ventilation on the bottom. My budget is $1000-1300 usd not including the os. Right now I have a build I made
http://pcpartpicker.com/p/wcmWyc
Is that build good enough? Should I change some parts? Thanks in advance.
https://linustechtips.com/topic/249219-first-build-_/
when they say not the os do they mean they r going to pirate????
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/249219-first-build-_/#findComment-3418035
This is an incredibly well picked out system for a first-time builder. Very nicely done!
I must ask though, are you purchasing the fans for looks? If you're thinking your case will need them - it won't, it comes with fans pre-installed
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/249219-first-build-_/#findComment-3418041
Ah, didn't know it came with fans. I shall remove them if they aren't necessary. I have a question though, should I buy an additional 120 mm fan for the top since the h100i is 240 mm and the top of the case supports up to 360, or should I just the h100i by itself?
https://linustechtips.com/topic/249219-first-build-_/#findComment-3418118
