OK so i got a usb 16gb and got afirend macbook pro and ownload yosmite then unibeast and multibesat.
i formatted the usb to mac os extended but didnt partion just used the disk utilitty erase tab and made it mac os extended.
then i did unibeast and it went flawless installed then i put the multibeast folder on the usb.
then that was it with the macbook i was finished, when i got home i changed my mobo setting to default and yeah.. usb boot 1st.
then when i boot it comeups with the apple and underneath USB and ??????
usb has the yosmite rock pic and ?????? has windows pic.
i went in the USB and it shows the apple logo for one sec an then resatrts and then i do thesame and it restarts.....
it was a clean out of box ssd
my pc is
i5 4690k
7950
msi z97 pcmate
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/249190-help-help-help-mac-yosmite-boot/
Uhm..
From my perspective, you're going to have to rework this post. I can't make heads or tails of what's going on here.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
are 7950's even usuable in mac OSX?
yes, they work out of the box
OP hackintoshes arent guaranteed to work. with that being said why did you reset your bios? if you had to change some settings to get OSX installed you will need them to stay that way for it to boot aswell
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
Re-read this over: http://www.tonymacx86.com/445-unibeast-install-os-x-yosemite-any-supported-intel-based-pc.html
You have multibeast on the flash drive currently? Remove it from the flash drive and try it again. There are also numerous boot flags that you can set if the install fails to boot from the Chimera bootloader. Use Multibeast only after an successful install.
Please fix your original post. Others, including me, are having a hard time understanding. Be concise and list each step, and where it fails at install. Maybe take a photo for us to see what's going on?
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
