  • 1 month later...
I have a wireless usb in my computer that gives me wifi but when i plug in my usb stick only the usb stick works and i get disconnected from the internet when i remove my usb stick the internet works again? Any way fix this problem?
are you plugging them into a hub or ports on the computer directly?
https://linustechtips.com/topic/24901-usb-wifi-problems/#findComment-529328
