hello,
i'm building a new pc and i'm not sure which cpu to use. i will only be gaming and playing some movies/music on here. if i plan to stream etc i will change the build accordingly. all i need to know is which cpu to get.
pc specs:
gtx 970 or r9 290
msi z87i gaming AC
silverstone raven rvz01
crucial ballistix sport 8GB
seagate barracuda 7200.14
silverstone SFX ST45SF 450W
i've been looking at the i3-4360 or the i5-4440. can i go any cheaper than this for this build and which one would you recommend?
thanks in advance!!
current rig (march 2023)
case: Corsair obsidian 750D   mobo: Gigabyte X470 Aorus Ultra Gaming   cpu: AMD Ryzen 7 5800x   cooler: Arctic Liquid Freezer II 240   memory: G.skill 32GB DDR4-3000   gpu: EVGA RTX 3070 XC3  PSU: seasonic X-series 850W
https://linustechtips.com/topic/248925-multimediagaming-mini-itx-build/
Budget
Please give us a budget please ..... Also what do you have already ? Monitor? OS System ? Keyboard and Mouse etc.
sorry the budget is the i5-4440 i dont want to go any higher than that. its going to be on my tv downstairs and i dont need an OS and keyboard and mouse has already been taken care of.
i mean for the system and go for the 970 and the build looks fine
Steve
Personally I'd go APU and stream games from your current PC via Steam. Cheaper than putting a 970 in a multimedia system.
i've been thinking about that too but i want to play games with my brother and you cant do that while already streaming a game.
about €750,- to €850,- and for the cpu about €160,-
True. I'm waiting for Steam to allow games to run in the background, and multiple games at a time. Bring on the 5960X/quad 980 (not even bothering with SLI, each running independently) gaming server running games simultaneously across the house...
...when that happens, THEN I'm building a streaming pc xD
i wont be building a streaming pc though. i would just get a cheap laptop with ethernet and hooked up to my tv or even a barebones brix thing.
go for the i5 and 970
is the i5-4440 much better in gaming than the i3-4360? its a €30,- difference.
yeah according to gd about 43% and get the 4460
if its really about 40% i absolutely will get the i5-4440 or the i5-4460
Yeah, Also get an after market cpu cooler. from my experience the Intel cooler has performed abysmally
yeah i know but the problem is i cant find anything that is good and fits into the case. the RVZ01 has a seperate space for the gpu so the cpu shouldn't get that warm though.
http://www.informatique.nl/887347/noctua-nh-l9i.html
Steve
