Hey guy's i want to build a desk with my PC in it,
my PC isn't very high end the price was like 1000$ when i build it.
i want it water cooled so you see tubing and stuff but i never water cooled can you guys please help and give tips / opinions!
Thanks! :)
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/24848-water-cooled-desk/
Read the 101 and FAQ stickies at the top of this forum section to start with.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/24848-water-cooled-desk/#findComment-314558
I'll check it out! :)
https://linustechtips.com/topic/24848-water-cooled-desk/#findComment-314564
Just curious but have you built anything as extensive as a desk? I was recently just thinking about building one myself but then after all the math and everything, the desk total would end up costing more than my already rather high end computer, and if you are playing around with that much money you want to make sure you really know what you are doing. you also want to make sure the desk is strong and wont just fall down once you do everything with it. If you do need help though feel free to ask me and you may want to check out http://linustechtips.com/main/topic/13922-custom-water-cooled-desk-56k-warning-lotsa-pictures/
That could help some and maybe even talk to him, see if he can give you some pointers. I hope you are in for some work because there will be A LOT if it but good luck and as i said, feel free to ask me any questions ill try to ask as fast as i can :D
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/24848-water-cooled-desk/#findComment-314638
Yes i have build a desk before and it was way better than an Ikea desk, haha but i also was playing around with the taught that i could buy a table and modify it so my PC could fit in there. maybe that's a better idea.
https://linustechtips.com/topic/24848-water-cooled-desk/#findComment-314809
