http://pcpartpicker.com/user/djexquisite92/saved/jZtkcf
Ok so after tons of research this is what I've came up with. I want a really good gaming system able to play all of the newest games on max but if you guys feel anything is unnecessary or would change anything please let me know because I could always stand to save some money lol.
https://linustechtips.com/topic/248424-first-gaming-build/
Why buy G-Sync + Monitor when you could buy a G-Sync Swift instead? I'd also recommend changing ram to something like Corsair Vengeance Pro or HyperX Fury so you can nicely colour match - if thats something you want to do.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/248424-first-gaming-build/#findComment-3407325
That monitor costs nearly $900 but his is less than $500 so its just a smart way to save some money ;D
Everything seems good to me, seems like you really did your homework (maybe you could take the RAM down to 8GB)  ;) being in the UK makes it hard for me to judge prices but it doesnt seem too unreasonable!
CPU: AMD FX6300 Motherboard: MSI 970A G43 RAM: 8GB Corsair Memory GPU: NVidia GTX 770 Case: Fractal Design Define R4 White w/ Window Storage: 180GB SSD + 2TB HDD PSU: Corsair RM850 Display: HP IPS 1200p Cooling: Fully Watercooled Keyboard: CM Storm TK White  Mouse: Razer Deathadder Sound: Temporary Speakers Operating System: Windows 8.1 Pro Phone: OnePlus One 64GB Sandstone
LOOKING TO UPGRADE TO DUAL 970's FOR DAT 4K!
https://linustechtips.com/topic/248424-first-gaming-build/#findComment-3407330
Change your RAM to 8GB. You won't utilize more than 8GB in gaming. Change the case with a 730T if you really want the looks/design. Other than that, you're good. :D
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/248424-first-gaming-build/#findComment-3407333
Get only 8GB of ram instead of 16, you don't need a ton for gaming.
Get a much cheaper case, that one you have selected is quite pricey. (I personally like the Air 540, looks amazing, shitloads of space too!)
What is this "Gsync" at the bottom of the list? I'm guessing its the GSync module for monitors.
https://linustechtips.com/topic/248424-first-gaming-build/#findComment-3407334
Yep, the G-sync module is available through Digital Storm online. You send in your ASUS VG248QE and they add the G-Sync support for $300.
I'm that guy with the GPD Win.
https://linustechtips.com/topic/248424-first-gaming-build/#findComment-3407372
Thanks you all for your feedback. I'm really lokking forward to start building this and jump into the world of PC Gaming. :)
https://linustechtips.com/topic/248424-first-gaming-build/#findComment-3407557
Anytime dude! I wish you the best of luck :) If you ever need any help feel free to post on here, we love helping first time builders!
#PCMasterRaceInitiate
https://linustechtips.com/topic/248424-first-gaming-build/#findComment-3407568
