No, your RAM needs to have the same specifications in order to run properly. This is why most RAM comes in an identical pair of 2 or 4. It's best to stick with the same model, however you could use 1x Corsair and 1x G.Skill RAM stick together if they were the same voltage, speed, etc.
https://linustechtips.com/topic/248250-ram-help/#findComment-3409537
