Hello all,
I have a HP laptop of which the monitor's native resolution is 1366*768, and I was wondering if it was possible to display things at a resolution beyond that using software trickery. I know I will lose clarity, but I just want to see what it would be like.
This is not for gaming, I would just like a little more screen space for productivity. The laptop is running Windows 8 and has a AMD Raedon 5650M running the 13.6 Beta Catalyst version.
Thanks!
EDIT: In case it wasn't clear, I am aware that you can't simply add more pixels. What I meant was is it possible to make a monitor seem like is is displaying at 1080p, when it is actually a 1366*768 monitor.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/24802-increase-display-resolution-beyond-native/
The native resolution is telling you how much pixels your display has. Pixels are a physical thing, you can't just add more.
I know. What I meant was, decrease DPI beyond what windows allows. Something like this http://superuser.com/questions/80151/how-to-setup-custom-dpi-below-100-on-windows-7?
