Hello. I am thinking about getting the Corsair K70 RGB and I'm just wondering if it is compatible with mac (the software to make change the lights).  I will be stuck with mac for a while still (which sucks hard) and any help is appreciated!! Also, if you know if or when it will be compatible that will be very helpful!!
Thank you!
REEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
https://linustechtips.com/topic/247915-compatibilty-help/
I'm not sure, but if it's not I think you can use a Windows computer to configure it and then use it on your Mac.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/247915-compatibilty-help/#findComment-3400132
