Okay, guys!
I need the smallest case possible, but it has to fit at LEAST a GTX 970 (probably the MSI G1 gamig version, or the Asus STRIX) and it MUST have a window, cause, you know. Computers are pretty.
So far, I'm considering a Corsair Carbide AIR 240 case.
Is it good? Any opinions or recommendations? Any advice on what parts to use?
I plan to use a 1080p 144Hz monitor.
Thanks in advance :)
https://linustechtips.com/topic/247319-mini-case-help-needed/
Carbide air is very poor build quality and not really mini.
I would either get a node 304 or the corsair 250d for long gpus in a fairly small case. Both also support decent heights which the air 240 definitely does not. You can't go higher than a reference card and even with that the power connectors will tocuh the window on the 240.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3392873
If you go for a shorter version like the zotac 970 you could even get away with using the elite 110 or if you want something to show off the jonsbo u2.
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3392995
Do you only play games or what else do you want to do? Do you want to overclock? Any color scheme? Water or air cooling preferred?
Any brands that you really want?
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3393775
This rig will be used for a lot of gaming, maybe some light video and photo editing. I don't really plan to overclock unless I have to, I don't really mind what brands, although I'd much rather have a Nvidia card instead of an AMD one, simply because of shadowplay, and the green colour scheme on the Nvidia cards. I don't mind water or air cooling, whatever you think is needed. I don't need it to be super quiet, either, since I'm going to be using headphones.
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3400573
I like the Corsair 250D the best so far, because it has windows.
What would you guys recommend for the parts and such?
I have a budget of anything under $2000. Planning to play on 1080p 144Hz monitor.
Have you look at Thermaltake Core v1 ? kinda look likes copies of 250d but cheaper
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3402088
Okay, guys!
Silverstone SG09/SG10, it's a squeeze but I had 2 3.5"HDD, 2 SSDs and a full size graphics card which ran cooler than my enthoo pro.
Very air optimised and you can fit a full sized CPU cooler in it as well as sli blower type GPUs, good option if your not going to play around with the hardware often.
A bit dated on looks though and no windowed version. LEDs look good behind the fans though
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3403162
You want small? Contact Parvum Systems about their ITX case. Here is a build log:
http://forums.overclockers.co.uk/showthread.php?t=18630671
They are so expensive but VERY nice.
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3409314
SilverStone sg07/08/09
Or lian Li PC-q36
https://linustechtips.com/topic/247319-mini-case-help-needed/#findComment-3412247
