Recommend Me Some Case Fans
Solved by WoodenMarker,
So I found out the problem was my 3-pin on my mobo runs the fans at full speed no matter what. The Enthoo Pro stock fans are actually quiet if they're plugged into a PWM header, but they aren't PWM fans so that's weird.
4pin is backwards compatible with 3 or 2 pin. The fans are running slower because they are being controlled by lowered voltage instead of pwm.
Featured Topics
Blasty Blosty ·
Posted in LTTStore.com Merch4 -
KeradSnake ·
Posted in Troubleshooting2 -
zonetrooperex ·
Posted in Storage Devices3 -
5
J98 ·
Posted in Graphics Cards7 -
2
VijayArun ·
Posted in New Builds and Planning8
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
