I bought some REALLY cheap ones for like 9$, they came with horribly sleeved cables, crappy built hardware and the stickypads that came with fell off after like 2 days lol :/
Do you live by a batteries plus? I was there the other day and I saw LED strips that were like 5 feet long, for 20$ and you can cut them to your length desire+ change color.
I think they were SYLVANIA brand
https://linustechtips.com/topic/24726-led-strips-under-10/#findComment-313239
If your willing to do the wireing and stuff yourself and dont care about the quality, just search "led strip" on ebay. You can find them in up to 5m rolls for only a few dollars from china
Aussie FTW!
4770k, H60, GTX 780, G1 Sniper 5, Samsung EVO 250GB, Seagate 2TB, Vengance Pro RAM 2133mhz 8GB, Silverstone Strider 850w
The Monolith Desk - build log incomplete.
https://linustechtips.com/topic/24726-led-strips-under-10/#findComment-313946
Its already been mentioned but if your comfortable doing a bit of wiring/soldering (really simple actually, just connect the 12v and ground to wire up to a molex or fan connector) then you can just buy strips of ebay really cheap. I got 1m strip of leds for like $3 + free postage off ebay and just wired them up them up a molex connector.
https://linustechtips.com/topic/24726-led-strips-under-10/#findComment-314250
