£30 should get you a Samson C01u? That's a condenser microphone so pretty damn good. Might need to spend another tenner on a desk stand, but if you want quality, that's the lowest you're going to want to go. Can also have a look if you can find a used one somewhere if you don't mind that.
https://linustechtips.com/topic/246935-microphone-help/#findComment-3388566
