So I installed metro 2033 and when I try and launch the game it pops up saying this
The program can't start because PhysXLoader.dll is missing from your computer. Try reinstalling the program to fix this problem.
Should I re install or is there another way to fix the problem?
Cheers
https://linustechtips.com/topic/246739-metro-2033-problems/
If you have the game on Steam, try verifying the game cache.
Just right click the game →´Click ´Properties´ → Click the tab ´Local Files´ → Click ´Verify intergrity og game cache´
My best guess is that your use a AMD GPU. Those always have this problems with Metro 2033.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/246739-metro-2033-problems/#findComment-3386571
it says
1 file failed to validate and will be reacquired
now what do I do?
https://linustechtips.com/topic/246739-metro-2033-problems/#findComment-3386590
it says
1 file failed to validate and will be reacquired now
You should let it download the missing file. Hopefully this will fix the issue.
https://linustechtips.com/topic/246739-metro-2033-problems/#findComment-3386640
