Hi guys, so I'm a little worried about my GPU it seems to run at around 80-87 when playing games and was wondering if this is normal on idle it runs 40-50.This is my current build:
  • CPU
    AMD FX-8320 8 Core Black Edition Processor
  • Motherboard
    ASUS M5A99X EVO Motherboard R2
  • RAM
    Kingston Hyper X Fury HX318C10FBK2/8 8GB (2x4GB) Black
  • GPU
    MSI Radeon R9 290 Gaming 4GB
  • Case
    Corsair spec-01
  • Storage
    Western Digital WD Blue 1TB WD10EZEX
  • PSU
    Antec High Current Gamer 620W Modular HCG-620M
  • Display(s)
    Acer K242HL 24in LED Widescreen Monitor
  • Cooling
    Corsair Air Series AF120 Quiet Edition Red LED Fan (1 at front and one at back)
https://linustechtips.com/topic/246734-is-it-to-hot/
get more fans and maybe a watercooler for your cpus so there will be less hot air in your case
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/246734-is-it-to-hot/#findComment-3386526
AMD says 95C is okay. So, you're fine. But yeah I wouldn't like my GPU to be that hot either.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/246734-is-it-to-hot/#findComment-3386527
Are you using a reference cooler? Try buying a Kraken G10 and buying an AIO to cool that. :D
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/246734-is-it-to-hot/#findComment-3386537
^Yet I would STILL WORRY
Those idle and load temps are a little on the high side.
I idle at 36-42*c and load @ 66-75*c depending how long I'm gaming for.
You need better airflow in that case.
Also set a higher fan speed progression via MSI Afterburner's Fan control, I can't really hear my GPU @ 40% at all, so thats now my minimum instead of the defaulted 25-30% fan speed.
I Also ramped the fan curve up @ 65*c to higher than default, yes sure it's more audible, thats a no brainer, but it's also not hitting 75*c EVER.
More case fans (even at low speeds) to move more in and out of your case is probably the best bet.
Exhausting more outwards would mean that heat does not POOL up within your case
Increasing the intake fan speed has benefits too.
Try manipulating your fan speeds a little faster and then see how it goes.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/246734-is-it-to-hot/#findComment-3386559
I've been running a card that hit 95c for over 5 years now and it's still a champ. Even ran it for mining bit coin when it was profitable years ago.
https://linustechtips.com/topic/246734-is-it-to-hot/#findComment-3386567
Don't mean to be rude but thats ONE card.
Regardless of even that, it's not healthy in MANY regards,
adding that extra ambient heat to other PC parts within the case is not good.
adding the extra heat to your room, can be quite comfortable in certain locations of the world.
Even if their rated for that, most PEOPLE are not capable of seeing it as acceptable.
I don't mean to be offensive if it comes across that way, just discussing.
https://linustechtips.com/topic/246734-is-it-to-hot/#findComment-3386574
