How powerful of a cpu do i need to run games like DOTA2, LoL, and Starcraft2 on 1080p 60fps with no/mild overclocking.
This is the MoBo i plan on getting  -  http://pcpartpicker.com/part/asrock-motherboard-h97anniversary   Does this motherboard even have the capability to OC, if not what motherboard should i get???
Thanks for any help :)
Runescape player  II  Civ 6 and LoL noob  II
https://linustechtips.com/topic/246629-what-cpu-should-i-get-help/
How powerful? A pentium will do
What would i recommend? any i5 k series with a z mobo.
And as far as i know H series MOBOs doesnt support OC
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
Most do nowadays, although you still need (or really should) go with a z board for any overclocking more than the g3258.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
If you don't want to OC, I'd say the 4690 should be good enough, or the i5 4440 if you want it for cheaper.
Getting a K-skew chip is only necessary if you intend to OC, and really, for Dota, LoL and Starcraft I don't think they're gonna be taxing those CPUs all that much.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
For those games, the 20th Anniversary Pentium or any i3 should be sufficient.
H97 motherboards do not support overclocking. If you're looking to overclock, Z97 boards are the way to go.
All boards, even H81 boards do support overclocking now; but they're not really designed for it, and as such its not a great idea to try and overclock anything more than a G3258 on one.
PSU Tier List | CoC
