is there a way to lower this prices build to 1200 with (13%) tax
i also need it to have the i7 for rendering and i already have the gpu okay
http://ca.pcpartpicker.com/p/rndFHx
Cpu: i7 4790k Mobo: Asus z97-A  PSU:Ultra Semi-Modular 850w SSD: Kingston 240gb HDD: Segate 1tb Ram: 2x8gb G.Skill ram GPU: Zotaz GTX 980 AMP! Case: Fractal Design Define R4 Windowed
https://linustechtips.com/topic/246546-11k-build-need-help/
Try not to double post.
You could get a cheaper case and monitor. If you get a mobo with AC you can ditch the wifi card. Hold on.k
k and i dont know why it doubled it just happened
https://linustechtips.com/topic/246546-11k-build-need-help/#findComment-3384146
Double post! Banned!
i didint know it double posted
https://linustechtips.com/topic/246546-11k-build-need-help/#findComment-3384177
He's just teasing you, he does that to everyone...
Not a whole lot you can do, I'm afraid. You can save some more moneys if you lower your case to something like a Define R4 or a Core series case. there are cases that will work perfectly well that are only like $40 or so.
If you're happy with just a membrane keyboard, go to staples or somewhere and get a cheap keyboard. it'll work just as well. Save yourself $50.
https://linustechtips.com/topic/246546-11k-build-need-help/#findComment-3384293
okay thanks
https://linustechtips.com/topic/246546-11k-build-need-help/#findComment-3385063
