Size & what theme colour/design do you want?
He might as well do the research himself then :P @nmc678
Define R4 from Fractal is quite popular. I personally like the White model but it has gotten a little dull & ugly.
S340 from NZXT is a decent pick though I would definitely put a custom cover to prevent me from looking at the ugly floor
I would suggest the 760T but that costs $200 I think (can't 100% remember) in white then spray paint it orange, or get the 730T then mod a window onto the side panel.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/246100-case-question/#findComment-3378257
i thought about that but i cant have that big of a case because i keep it on my desk because my dog pisses on things lol
https://linustechtips.com/topic/246100-case-question/#findComment-3378277
730T is your best choice for ATX Orange cases imo. Unless you want to spend about $100 dollars on a case then spray paint it your favourite colour.
https://linustechtips.com/topic/246100-case-question/#findComment-3378334
