Network dropping connection constantly
Solved by Toddwjp,
I have no network admin permissions, so I am not allowed to reset any router, as for the network type used is simmilar to a school where it is all from the server whickh acts like the router and switch, as for shutting down the whole thing is just not doable according to management.
as for ISP it is some small Idaho only company called "Always On". the problem started spreading to other computers so The router must just hate us. thanks for the help, though.
no go to windows network and sharing centre, delete all profiles and restart you computer
