Noctua Fans on H110
Solved by ROK,
It is possible the fans are different depths and so the screws won't fit though, right?
The depths won't vary enough for there to be any issue. NF-A14s are a very standard 25mm, which is the same depth as corsair's 140mm fans that they sell separately, which I highly doubt wouldn't be compatible.
http://www.corsair.com/en-ca/air-series-af140-quiet-edition-high-airflow-140mm-fan
http://www.noctua.at/main.php?show=productview&products_id=52&lng=en&set=1
Check those links to verify if you must.
You will be OK.
